jcharles's avatar
jcharles
Initiate
Jan 19, 2020
JGS524E et firwmare upgrade with ProSafe Plus Utility
Hello,   I would like to updgrade the switch firwmare from 1.00.09 to 1.00.21  with ProSafe Plus Utility (version 2.7.7) but when I click on the radio button, nothing is happening.   Do you have ...
  • jcharles's avatar
    Jan 19, 2020
    I find the solution.
    In the ZIP containing the firmware and a release notes, it is mentionned that you must click on the radio button next to the switch and nothing is happening if you do that.
    1. Download the new firmware to a convenient place on your local system and extract the ZIP file (e.g., C:\downloads\).
    2. Start ProSafe Plus Configuration Utility, (included on the CD coming with your Smart Switch). If it is not installed, do so now, before continuing.
    3. The ProSafe Plus Utility will scan and detect ProSafe Plus switches on your network. Select the switch to upgrade by clicking on the radio button next to the switch. Enter the adminstrator password of the switch when prompted.
    4. Select Maintenance under the System tab. Click on Firmware Upgrade and Browse to the location when the firmware image is saved.
    5. Click Apply to start firmware upgrade.
    In order to upgrade the swith (or manage it) you have to click on the action button named 'Apply' ou 'Appliquer', enter the password and you will access to the interface.
    Click on 'Maintenance' and 'Upgrade firmware', select the firmware file and click on 'Apply'.
ProSupport for Business
