bmm85
Jun 21, 2022Aspirant
JGS524ev2 & JGS516PE loosing some vlan configuration after reboot
Hi, after a power cut I noticed that my vlan configurations were wrong. I reconfigured them to get the network work again. Afterwards i gave it a retry. I am rebooting the switches via the u...
schumaku
Jun 21, 2022Guru - Experienced User
Have no such models at hand for a test (I'm not with Netgear). What firmware is in place on these two models?
https://www.netgear.com/support/product/JGS524Ev2.aspx#download currenlty 2.6.0.48
https://www.netgear.com/support/product/JGS516PE.aspx#download currenlty 2.6.0.48
If current, the issue remains, and a factory reset and a scratch reconfig does not change the effect, what Web browser is used for the config? Does the WebUI show a different config after the reboot?
