Retired_Member
Jul 20, 2022JGS524EV2 PROBLEMS
I have a number of related or unrelated issues with switch: Just updated firmware using utility to 2.0.1.26. After update unable to log onto switch using Prosafe utility . Was ok before update ...
Retired_Member
Jul 20, 2022Update
Managed to connect using switch discovery tool and firewall turned off. Switch discovery tool found switch and presented option to open web UI.
Logged in using password which was changed to default wither by multiple attempts to hardware factory reset or with firmware update
Updated firmware again and this time it loaded and restarted swtich
Then changed p/w
Then selected option to connect via web UI or Porsafe Utility
Logged off
Restarted firewall
Logged in again ok with proafe utility
