DigitalSurfer
May 31, 2025Aspirant
JGS524Ev2 won’t factory reset with paper clip. Can’t apply any changes in management
Hello, I would be grateful for some help. I was thinking I would update the firmware to the latest version but when I log on to the switch the apply button won’t highlight or do anything. I tried t...
DigitalSurfer
Hello again schumaku,
I was just about to reply, but thought I would just log back in to the WebUI to check again if I could make it work.
A strange thing happened! I noticed that the cancel and apply buttons were partly off the bottom of the screen... So I decided to reduce the zoom level of the monitor to see if they became fully visible...
Amazingly, the entire WebUI layout changed and all of the management functions became available!
I am pleased to report that I have been successful in updating the firmware and we are now on the newest version.
Thank you for your help indeed.
I wish you all the best and take care.
