michaeldaly600
Oct 26, 2023Follower
JGS524PE - ?can disable DDoS
The JGS524PE has Auto “denial-of-service” (DoS) prevention. You don't seem to be able to turn this off. But after extensive research, this seems to be causing problems with an ESXi backup as wel...
ErikO
Nov 08, 2023NETGEAR Moderator
Hello Michael,
This very much looks like an automated function and there are no options in the GUI to disable the auto-DDOS. In other words, we can't turn off the auto-DDOS function on the JGS524PE "Plus" switch.
Have a great rest of the day nonetheless,
Erik O
