fa355115
Oct 08, 2017Aspirant
JGS524PE - What is my actual PoE consumption ?
Hi there, I have a JGS524PE with at current 3 IP cameras connected and using PoE, and would like to add some more cameras. Is there a way to know how much PoE I already use ? I see that the max ...
- Oct 15, 2017
I'm afraid to inform you that there is no way to monitor the actual PoE consumption "live." However, you may want to post this concern as feature request to the Idea Exchange for Business board here. In this way, the development team can see what feature does the JGS524PE switch users like you wanted to be added to the functionality of the product.
DaneA
NETGEAR Community Team
DaneA
Oct 09, 2017NETGEAR Employee Retired
Hi fa355115,
Welcome to the community! :)
The PoE consumption of the JGS524PE depends on the following:
a. PoE load
b. number of PD (Powered Devices) connected
c. length of the ethernet cable being used because the JGS524PE supports 802.3az Energy Efficient Ethernet (EEE) function
Considering only the power consumption of the JSG524PE, it is expected to be 6W.
What is the PoE Class of your 3 IP cameras?
Here are the different PoE classes:
Kindly read the following articles:
What is PoE? (Power over Ethernet)
Power over Ethernet(PoE) standards and compatibility (2008)
Here below is a good read about Power Allocation on PoE NETGEAR Switches:
DaneA
DaneA
Oct 15, 2017NETGEAR Employee Retired
DaneA
- fa355115Oct 17, 2017Aspirant
Thanks a lot for the confiration !!
