driver8
Jan 30, 2022Aspirant
JGS524PE 2.6.0.48 - Memory leak?
I have a problem with this switch where after about 5-7 days of use it simply grinds to a halt, and the only thing that will fix it is a reboot/power cycle. Is it possible there is a memory leak in t...
DaneA
Jan 31, 2022NETGEAR Employee Retired
Welcome to the community! :)
Try to perform a factory reset on the JGS524PE and observe if the same problem will occur. If ever the same problem recur, kindly access the JGS524PE product support page here then click on the button that says 'Guided Assistance' for a hardware check with the NETGEAR Support Team. If the switch is proven faulty, an online replacement will be processed for as long as the device is still within the hardware warranty.
DaneA
NETGEAR Community Team
- driver8Feb 07, 2022Aspirant
Do you think it is likely that it is a fault, given that it only happens after at least a week of working OK? Also, if it is a fault, how will Netgear support identify it if it only happens after working OK for a week?
- DaneAFeb 09, 2022NETGEAR Employee Retired
As far as I have checked, there is no issue logged that describes exactly or similar as per your initial post in which it is possible that your concern is an isolated case wherein the hardware is at fault.
Possibly, the NETGEAR Support Expert will configure Port Mirroring on your switch and get a packet capture. The packet capture will run until the event the issue happens. Then, the captured packets will be analyzed.
DaneA
- driver8Feb 09, 2022Aspirant
That is very helpful. I will contact them to see whether they can do that.
