driver8
Jan 30, 2022Aspirant
JGS524PE 2.6.0.48 - Memory leak?
I have a problem with this switch where after about 5-7 days of use it simply grinds to a halt, and the only thing that will fix it is a reboot/power cycle. Is it possible there is a memory leak in t...
driver8
Feb 07, 2022Aspirant
Do you think it is likely that it is a fault, given that it only happens after at least a week of working OK? Also, if it is a fault, how will Netgear support identify it if it only happens after working OK for a week?
DaneA
Feb 09, 2022NETGEAR Employee Retired
As far as I have checked, there is no issue logged that describes exactly or similar as per your initial post in which it is possible that your concern is an isolated case wherein the hardware is at fault.
Possibly, the NETGEAR Support Expert will configure Port Mirroring on your switch and get a packet capture. The packet capture will run until the event the issue happens. Then, the captured packets will be analyzed.
DaneA
NETGEAR Community Team
