Dwade504
Jun 26, 2016Aspirant
JGS524PE connecting 2 to Fortigate
I have a simple LAN with a cable modem, followed by a FortiGate 60 firewall, then 2 JGS524PE switches. The FortiGate has several internal ports for connections. Would it be better to connect each s...
- Jul 01, 2016
Hi Dwade504,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
JohnRo
Jun 28, 2016NETGEAR Employee Retired
Hello Dwade504,
Welcome to the community!
Daisy-chained vs directly connected doesn't really seem to have a big difference when it comes to speed and performance. However, I'd personally use direct connect to the router since it is more fail-proof than two switches connected to each other. If the main switch connected to the router fails, then the second switch connected to it will lose connection. Creating a VLAN is not necessary since you can configure QoS settings on the switch. QoS Configuration helps you maximize the use of bandwidth per port.
Let me know if you have more questions, otherwise please mark this post as "Accept as Solution".
Thanks,
