Dwade504
Jun 26, 2016Aspirant
JGS524PE connecting 2 to Fortigate
I have a simple LAN with a cable modem, followed by a FortiGate 60 firewall, then 2 JGS524PE switches. The FortiGate has several internal ports for connections. Would it be better to connect each s...
- Jul 01, 2016
Hi Dwade504,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
JohnRo
Jul 01, 2016NETGEAR Employee Retired
Hi Dwade504,
Thanks,
