Noah_Boddy
Mar 10, 2025Aspirant
JGS524PE password reset loop
I lost the password for my JGS524PE switch. After I pressed the reset button for 30 seconds, entered the default password "password", the Change Admin Password gui pops up. No matter what password ...
- Mar 10, 2025
Switched to Chrome and was able to get past this issue. Thanks.
Mar 10, 2025Guru - Experienced User
What browser are you using?
Be sure to clear out all browser caches and any saved PW profiles for the switch with in the browser.
Try a different browser as well.
Try a different PC to compare results.
- Noah_BoddyMar 10, 2025Aspirant
- FURRYe38Mar 10, 2025Guru - Experienced User
đ
