dumbo25
May 01, 2020Tutor
JGS524PE running v2.6.0.43 with PoE not working
I have a working device that can be powered from other PoE switches. The device draws 5.1v at up to 2amps. It is 802.3af compliant.
I reset the JGS524PE to factory defaults, updated the software to latest version, rebooted, and tried other PoE ports.
Supposedly, PoE is setup by default on the JGS524PE, but there is no page or indicator in ProSafe showing PoE status.
Any help getting this working woul dbe appreciated.
My post above can be deleted. I had something set wrong on the device.
1 Reply
- dumbo25Tutor
