arainero
Jan 03, 2017Aspirant
LAG across multiple (stacked) swtiches
Hello, I was wondering if this sceneario is possible and if it is the best one for a highly available network. If I had two switches that were stacked can I LAG a port from each switch for re...
- Jan 03, 2017
Hi Arainero,
Welcome to our Community !
Yes you can LAG the switches across the stack, that's called normally distributed LAG. This is possible because we provide a "Physical" Stacking across all our switches so you can create LAGS using different switch ports.
Hope that it helps.
Xavier Lleixa
NETGEAR CBU PLM
XavierLL
Jan 03, 2017NETGEAR Employee Retired
Hi Arainero,
Hope that it helps.
Xavier Lleixa
NETGEAR CBU PLM
- XavierLLJan 03, 2017NETGEAR Employee Retired
HI Arainero.
I forgot to answer your questiona about what happen if the switch A fails, in this case you are right all the traffic will be forwarded to the Switch B. On the server please make sure that you implement link aggregation 802.3ad to set up the LAG.
Xavier Lleixa
NETGEAR CBU PLM
- araineroJan 03, 2017Aspirant
Ok, great to hear. Thank you for your assistance.
