IOTdiot's avatar
IOTdiot
Tutor
Apr 28, 2019
LAGG with GS752TP and pfsense
I'm trying to get LAGG working between my pfsense box and GS752TP but it's not functioning properly.   When I have the settings to what I think are correct, the connection to the router breaks an...
  • IOTdiot's avatar
    IOTdiot
    Apr 30, 2019
    Issue resolved. It was a VLAN assignment issue.
    There is a visual selector called TRUNK below the PORTS area in the VLAN settings.
    Individual port trunks must be removed as members from the VLAN settings which are to be used as LAGG trunk members. And then add the LAGG group number to the specified VLAN's back as appropriate trunk member(s). Also the LAGG itself must be an untagged member of the base (1) VLAN, as well as the indivudual ports (but they cannot be trunks).
    As a side note, my old pfsense traffic shaper settings were causing internet issues and bugs within pfsense after the proper LAGG config was set. THe traffic shaper settings had to be removed.
ProSupport for Business
