tantony
May 03, 2019Luminary
Laptop can’t ping outside of subnet
I have two VLANs. One laptop on VLAN 2, and the other on VLAN 3. I’m able to ping both laptops from router and NETGEAR switch. But, VLAN 2 laptop can ping VLAN 3 laptop. VLAN 3 laptop can’t ping VLAN 2 laptop. I don’t have any firewall rules. I disabled windows firewall on both laptops.
VLAN 3 laptop can only ping other laptop on VLAN 3. I’m not sure why.
As suspected, it's a laptop issue. I tried another laptop, and I'm able to ping both laptop to each other from different VLANs.
There is no "magic" routing between subnets - that's the reason I often say one should not talk of "inter-VLAN-routing". The static IPv4 routing must be configured accordingly. Some routing capability must be avilable on your network, either on a dedicated router, on on an L2+/L3 switch.
