ITSGPete
Feb 14, 2020Aspirant
latest firmware update, now web interface doesn't work
Just bought a new ProSafe 24. Got it set up and configured with a management address on our network. Firmware was at level .40, figured I would install the latest .43 before it was put into service....
- Feb 15, 2020
The standard Microsoft solution fixed it (power off/on). Thanks all.
Serves me right for trying to do it remotely...
schumaku
Feb 15, 2020Guru - Experienced User
ITSGPete wrote:Got it set up and configured with a management address on our network.
Ok, assigning a fixed IP config is the way to go on the Smart Managed Plus devices - as the management VLAN can't be restricted, and DHCP can pick ip a config from any other VLAN.
ITSGPete wrote:Now can't login, get message on Firefox and Google that 'connection was reset'. I can ping the address just fine.
For some unknown reason, the Web UI does not come up.
ITSGPete wrote:Documentation says .43 disables the old Config utility, so don't have another way to get into the switch. Any suggestions?
Factory reset - no better idea.
ITSGPete
Feb 15, 2020Aspirant
