  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi ofuen,
    Welcome to our community! :)
    Here is the letter of volatility for GS516T. No password needed and the link will expire after 48 hour period.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    • ofuen's avatar
      ofuen
      Thank you. The response from this community forum is awesome.
    • ofuen's avatar
      ofuen
      Good Morning, First thank for response on LOV for the GS516T. I noticed that the LOV stated the there was no memory. Is there no non-volatile firmware in this product? My security officer is pretty sure it does. Any specification sheets available other documents available? Thanks Orlando
      • JohnC_V's avatar
        JohnC_V
        ofuen,
        I may need to inquire the lists of all the switches that has a memory. I'll get back to you once I got the information. But, definitely these type of switches doesn't have any memory or even a non-volatile firmware.
ProSupport for Business
