Mic-cosmos
Feb 28, 2021Follower
Link aggregation across switches
I'm trying to get static LAG to work spanning switches but it is not working Setup Clients-GS116Ev2#2=TL-SG108E=GS116Ev2#1=Synology -The connections between switches are static LAG -For som...
DaneA
Mar 21, 2021NETGEAR Employee Retired
1) Is it not possible to get LAG to work across GS116Ev2 with another switch?
3) Is it an issue with compatability with TL-SG108E and if I replace it with a Netgear-based switch with Static LAG on (e.g. another GS116Ev2), then I will be able to pull >1 Gbps?
The GS116Ev2 complies with the IEEE 802.3ad standard (LAG). Hence, if the other switch (such as the TL-SG108E) also complies with the IEEE 802.3ad standard, then it should work.
Kindly check the LAG settings of the TL-SG108E. You may want to check the current firmware of both switches. If ever its not yet the latest version, I suggest you to update it. The latest GS116Ev2 firmware is v2.6.0.48 and you can download it here.
2) Is it an issue with the way GS116Ev2#1 is connected to Synology even though locally I can pull >1 Gbps?
If this doesn't won't work, I advise you to open a support ticket with NETGEAR Support here at anytime.
DaneA
NETGEAR Community Team
schumaku
Mar 21, 2021Guru - Experienced User
DaneA wrote:
Not sure if you have already came cross with this. Let me share the KB article below:
If this won't work, ...
Afraid, I have to call back the high flying horses a little bit.
Dynamic link aggregation with LACP groups as per 802.3ad (more appropriate 802.11ax) on Smart Managed Plus switches is limited to a few newer models only: GS110EMX, GS750E, XS512EM, and XS724EM.
Support can't help or make wonders for other models, e.g. on the subject GS116Ev2 - the above linked KB entry does not apply here.
FWIW, static link aggregation is supported on the following models:
• GS110EMX
• GS116Ev2
• GS408EPP
• GS750E
• GSS108EPP
• GSS116E
• JGS516PE
• JGS524Ev1 (requires firmware v1.00.15 or a later version)
• JGS524Ev2
• JGS524PE
• XS512EM
• XS708E
• XS708Ev2
• XS716E
• XS724EM
