Mic-cosmos
Feb 28, 2021Follower
Link aggregation across switches
I'm trying to get static LAG to work spanning switches but it is not working Setup Clients-GS116Ev2#2=TL-SG108E=GS116Ev2#1=Synology -The connections between switches are static LAG -For som...
DaneA
Mar 21, 2021NETGEAR Employee Retired
1) Is it not possible to get LAG to work across GS116Ev2 with another switch?
3) Is it an issue with compatability with TL-SG108E and if I replace it with a Netgear-based switch with Static LAG on (e.g. another GS116Ev2), then I will be able to pull >1 Gbps?
The GS116Ev2 complies with the IEEE 802.3ad standard (LAG). Hence, if the other switch (such as the TL-SG108E) also complies with the IEEE 802.3ad standard, then it should work.
Kindly check the LAG settings of the TL-SG108E. You may want to check the current firmware of both switches. If ever its not yet the latest version, I suggest you to update it. The latest GS116Ev2 firmware is v2.6.0.48 and you can download it here.
2) Is it an issue with the way GS116Ev2#1 is connected to Synology even though locally I can pull >1 Gbps?
If this doesn't won't work, I advise you to open a support ticket with NETGEAR Support here at anytime.
DaneA
NETGEAR Community Team
