TylerLLee
Mar 02, 2025Follower
Link failure count increased during Linux bonding
Hello everyone,
When I bond the two interfaces of Broadcom P210TP in RedHat 9.3 or 9.4, and check the bonding status, the Link failure count is usually not 0. Most of the time both interfaces will show 1, sometimes only one interface will show 1.
Ethernet Channel Bonding Driver: v5.14.0-427.13.1.el9_4.x86_64
Bonding Mode: fault-tolerance (active-backup)
Primary Slave: None
Currently Active Slave: ens9f1np1
MII Status: up
MII Polling Interval (ms): 1
Up Delay (ms): 0
Down Delay (ms): 0
Peer Notification Delay (ms): 0
Slave Interface: ens9f0np0
MII Status: up
Speed: 10000 Mbps
Duplex: full
Link Failure Count: 1
Permanent HW addr: b0:26:28:71:33:20
Slave queue ID: 0
Slave Interface: ens9f1np1
MII Status: up
Speed: 10000 Mbps
Duplex: full
Permanent HW addr: b0:26:28:71:33:21
Slave queue ID: 0
Using the same configuration, I do not see this issue when I connect the P210TP to another switch (different manufacturer).
It should not be related to the bonding mode, as I have also tried different modes (mode 1 active-backup and mode 6 balance-alb).
Once I change the connected ports on the XS728T switch to 1G, the issue no longer occurs.
The P210TP's firmware and OOB driver are already latest, and I have also updated the XS728T to 6.5.1.74.
Additionally, I've observed that even when not bonded, unplugging and plugging the cable once results in two "Link down" logs appearing in the /var/log/messages, instead of the expected one.
Does anyone have any ideas?
1 Reply
Very, very unlikely a switch issue - much more an oddity of your U**x-like OS or it's drivers. Or have some unreliable cable or installation wiring?
The P210TP's firmware and OOB driver are already latest, and I have also updated the XS728T to 6.5.1.74.Are there really some wonky physical links that you operate fault-tolerance (active-backup)
or balance-alb? In my opinion, a waste of cabling and expensive connections and ports.While talking:
- The later one (balance-alb) requires the two switch ports configured as a static LAG.
- There is no OOB on the XS728T or the Asus P210TP network adapters, very unclear what you talking of here.
- Consider to configure a static LAG or an LACP LAG on the Linux system -and- the connected switch ports.
- I would not bother about a 1(and many low non-zero error counters in real world networking) ....
-Kurt
