Tom2244R
Mar 03, 2024Aspirant
Linked Speed limited to 100M between router and switch
Hello, I have a problem with my GS308E switch that I've had for almost 2 years. I use it in my living room to connect an Apple TV and a PS5. I noticed yesterday that my connection was not stable wi...
CrimpOn
Mar 04, 2024Guru - Experienced User
It is a bit frustrating that Netgear chose to omit the status LEDs on the Orbi Ethernet ports. (I can sympathize that many customers prefer not to have blinking lights when electronics are placed in bedrooms, and most of the time the Ethernet ports are not easily visible. But... that's a problem that electrical tape can solve. The only way to observe the connection speed on the router side is through the Orbi web interface, Advanced Tab home page, click the Blue box Show Statistics.
The Orbi router should display the speed of the LAN port that is connected (through the house wiring and patch panel) to the switch as the same speed as the LED's on the switch port:
i.e. Both left and right LEDs solid green on the switch should match 1000M/Full (Gigabit) on the router display.
Left LED green and Right LED off should match 100M/Full (Fast Ethernet)
This appears to be what is happening, correct?
The AppleTV must be a "4K" model, because that is the only model to include a gigabit Ethernet port.
Can you explain more about the comment:
- Connecting the Apple TV directly to the switch: 925Mbps, so the connection seems to be stable and work fine in this case.
I thought from the original post that the Apple TV is already connected to the switch in the Living Room?
Tom2244R
Mar 04, 2024Aspirant
Hello,
Thanks for the information. Yes it's an Apple TV 4K, and to test I connected it directly to the Ethernet without the switch and in this case I had a good throughput.
Anyway, my problem seems solved. For some reason, everything's been working again since yesterday evening, without me doing a thing. However, I did notice some CRC Error Packets on my switch interface. It doesn't seem to be too serious, as I haven't noticed any particular anomaly in use.
Thanks for your help!
