GearManager's avatar
GearManager
Looking at getting a second GS752TSB and have questions about stacking.
Hello all,
I am looking at possible getting a second GS752tsb switch and am told that it can support stacking and 10Gbps. The documentation mentions that the SFP stacking port provides bandwidths of 2.5G. So the question is to achieve the stacking speeds of 10G does it require to use 4 SFP connections and have them as aggregrated links?
  • 2 ports on the GS752TS(B) can be configured for stacking (ports 51 and 52). When configured in stack mode, the stack ports operate at 2.5Gbps full duplex. With 2 ports on a switch in stack mode, this is where the 10Gbps stacking bandwidth comes from (each stack port does 2.5Gbps in both directions).
  • I think you are correct. However, you want to set up all four links as "stack."
    Don't put them into a LAG if that is what you are thinking. LAG uses LACP standard that is not compatible with stack ports.
    • BrendanM's avatar
      BrendanM
      NETGEAR Expert
ProSupport for Business
