SteveinOrlando
Nov 14, 2020Initiate
Lost GS110TTP V2 switch power supply - need to order another one.
Hello -
I need to order a new power supply for a GS110TP V2 managed switch. What part number should I be looking for?
Thanks!
Steve
- DaneANETGEAR Employee Retired
Welcome to the community! :)
Here are the part numbers of the power supply for the GS110TPv2:
332-10290-01
332-10317-01
Since your concern has been addressed / resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team- SteveinOrlandoInitiate
Can this be purchased from NetGear? Power supplies with that part number from Amazon don't fit this switch.
SteveinOrlando wrote:Power supplies with that part number from Amazon don't fit this switch.
Why not? Because it does not list this switch model, eg. https://www.amazon.com/Adapter-NETGEAR-NU60-F480125-I1NN-NU60-F480125-I1-332-10290-01/dp/B01M9DTTKU ?
