MikeNeuffer
Sep 01, 2023Tutor
M4300 and Timer Schedules / time-range Status always goes to Inactive - How to fix?
We have several M4300 (52G/96x) and switches and I am trying to setup working schedules to switch off POE for several ports during the night and the weekends when the offices are empty. The invo...
MikeNeuffer
Sep 04, 2023Tutor
schumaku First of all thank you for you answer, however
as I wrote previously, the whole timer schedule goes to inactive as soon as I enter the first entry, so this already invalidates your comment.
I've documented the behaviour with a few screenshots:
Add a new Timer Schedule
Add new Timer Schedule
The Timer Schedule is active
The new Timer Schedule is active - but with no Schedules attached yet
Add a periodic Schedule to the Timer Schedule
Add the new periodic schedule to the Timer Schedule by clicking on the <Add> button (not in the screenshot). It makes no difference if I use a day in the past, todays date or some day in the future for "Day Start".
According to the documentation this schedule will run (ie switch off POE) Mon-Fri from one minute past midnight until 7am.
However:
The Timer Schedule has become inactive
Now the Timer Schedule has become inactive.
What is wrong here ? How to switch on the schedule?
Coming back to your posting, why should 00:00-00:00 not be a meaningful entry?
How else should I qualify that POE should be down on the port for the whole day?
00:00 - 24:00 is not a valid entry and results in an error:
"Error! Invalid 'Time End' format: 24:00"
Switching on POE for one minute per day (23:59 - 00:00) by setting it to 00:00 - 23:59 seems kind of non-sensical.
The devices (mostly, but not exclusively IP telephones) would start to boot, just to be choked off again almost immediately - not exactly very healthy for the hardware.
schumaku
Sep 04, 2023Guru - Experienced User
MikeNeuffer wrote:
Coming back to your posting, why should 00:00-00:00 not be a meaningful entry?.
You re arguing with the wrong person here my friend. Just another community member here, I can just answer based on some longer experience with several Netgear switch generations which don't support continuous and 24h schedules.
This would make more sense, however - your result is predictable ...
It won't kill any hardware if its powered up for one minute only. Not nice, I admit. Let's see of you can get some better answers from the Netgear side...
Had lengthy discussion in the past over this oddity already.
