solohaile77
Mar 22, 2023Aspirant
M4300 Fully Managed Switches Disable IP Routing and Dhcp Server Temporary.
Hi there,
I've been assigned to convert our core switches from layer 3 to layer 2 and migrating the dhcp server elsewhere for a project. I believe I found the options to disable both features. However, I want to find out if I disabled those two, would it wipe out what is currently running? For example, If I decide to turn them off and then I want to re-enable back. Do I have to start from Scratch or what was configured initially will be back again if I select the radio buttons for "enable"?
See screenshots below.
Thank you,
No RepliesBe the first to reply
