ubiq1er
Mar 05, 2021Tutor
Management VLAN on a good old FS726T
Hi, Just inherited a good old FS726T 24 ports Switch. I created some VLANs on it, but I couldn't find a way to define a management VLAN. Therefore, I can access to the Switch Web Managment page fr...
schumaku
Mar 05, 2021Guru - Experienced User
The data sheet linked does describe the later FS726T-200xxx (FS726Tv2) model - here for your reference (not that it answers your question I admit) the FS726T-100xxx (FS726Tv1) Data Sheet.
FMI the support links for both models:
ubiq1er
Mar 05, 2021Tutor
Ok, thank you for the precision about the DataSheet (that was actually a v2 Data Sheet).
As I find absolutely nothing about a Management VLAN for the FS726T v1, I think I can assume there is not such a feature for this model.
=> I guess I will have to choose an even stronger password to protect the Web Access Page.
- schumakuMar 05, 2021Guru - Experienced User
Be aware these FS726Tv1 systems are EoL for a long time, even the FS726Tv2 systems are EoL for around half a decade already.
