MASS_BH_'s avatar
MASS_BH_
Management VLAN
 I can't make change management VLAN form VLAN 1 to VLAN 10, when ever tried to change MGNT VALN am getting error.   SWITCH MODEL : GS724TPV2 prosafe ERROR! MANAGEMENT ACCESS WILL BE LOST ON MGNT ...
  • RennaD's avatar
    Mar 08, 2023
    Hello MASS_BH_,
    And welcome to the NETGEAR Community! 🙂
    To get rid of that Alert message you need to have at least one port to be a member of the VLAN you want to set as management VLAN. Since you already have VLAN 10 the following are the steps to change management VLAN:
    1. connect your computer to the switch, example: port1
    2. go to Switching - VLAN - Advanced - VLAN Membership
    3. for VLAN1 remove the "U" for any port except port1, example: port7
    4. for VLAN10 toggle port7 to "U"
    5. go to Switching - VLAN - Advanced - Port PVID Configuration
    6. set port7 PVID to 10
    7. change Management VLAN ID to 10
    To manage the switch you should now connect your computer to port7.
    Have a lovely day,
    RennaD
    Netgear Team
ProSupport for Business
