vulogiccl1
Sep 22, 2022Aspirant
Missing info on GS110TP
Hi I have a GS110TP running firmware 5.4.2.36 on a LAN with several other switches, including two other, different Netgear switches. Any network scanning or monitoring tools I may use on thi...
schumaku
Sep 23, 2022Guru - Experienced User
Reads to me as the tools you are trying do some basic things some IP stacks might discover, or use LLDP which is (as the name says) link layer discovery protocol which is never visible beyond the direct physical link.
Configure SNMP on your devices, and use an SNMP capable tool.
- vulogiccl1Sep 30, 2022Aspirant
The examples above are of the tester reporting its findings when connected directly to port 7 on the GS110TP (sw3), port 11 on the FSM726 (sw2), and port 22 on the GS724T (sw1) -- three different tests, with the tester physically connected to each device.
SNMP is configured on all devices.
