CHO29
Mar 21, 2026Tutor
Mosaic on decoded IP Stream
Hello guys, I have a network remote comprising of switch netgear gs724T. On One site two different stream are present on the switch with different Vlan and Multicast address Site A 1. Vl...
CHO29
Mar 21, 2026Tutor
The switch is GS724T v4. The firmware is 6.3.1.43.
the table is displayed and each port has its vlan required.
why this degradation in video occur? is there any configuration should be done?
Thanks
schumaku
Mar 21, 2026Guru - Experienced User
Nothing obvious does pop-up in my grey cells these minutes.
Worth having an eye on the
https://kb.netgear.com/000065818/GS716Tv3-GS724Tv4-GS748Tv5-Firmware-Version-6-3-1-47 Release Notes - ref. MLD snooping (IPv6 specific) and some potential signal issues on some higher port numbers.
