CHO29
Mar 21, 2026Tutor
Mosaic on decoded IP Stream
Hello guys, I have a network remote comprising of switch netgear gs724T. On One site two different stream are present on the switch with different Vlan and Multicast address Site A 1. Vl...
Mar 22, 2026Guru - Experienced User
CHO29 wrote:Site A
1. Vlan 111 - First IP Stream with a Multicast Address are pooled on port 3 4 & 5 to be connected on decoder and the stream are fine
2. Vlan 112 - Second IP stream with a multicast address is originated from an ip decoder and connected to port 11 and 12 where to be decoded on site b
On Site B
1. the Vlan 112 is beind decoded and monitored where the video is MOSAIC.
From site a to site b microwave link is used with a capacity 1 gbps and all config is ok
I am thinking that the switch is at Site A and that the VLAN 111 decoder is also on site A. Is that the case?
If so, I am guessing that there might be some packet loss on the microwave link. Do you have any way to see stats on the link?
If you temporarily put a decoder at site A (on Vlan 112), do you see the same artifacts?
- CHO29Mar 22, 2026Tutor
Hello,
The switch is at site A and the decoder for Vlan 111 is at site A confirm.
I have check the microwave link and it was checked by an expert but there was no packets loss on microwave link, no errors observed
If i put a decoder at Site A for Vlan 112, yes i see same artifacts!
- StephenBMar 22, 2026Guru - Experienced User
Ok, I think that rules out the microwave link.
If you switch the two sources, does the problem move with the source, or does it stay with the VLAN?
