CHO29
Mar 21, 2026Tutor
Mosaic on decoded IP Stream
Hello guys, I have a network remote comprising of switch netgear gs724T. On One site two different stream are present on the switch with different Vlan and Multicast address Site A 1. Vl...
CHO29
Mar 22, 2026Tutor
Hello,
The switch is at site A and the decoder for Vlan 111 is at site A confirm.
I have check the microwave link and it was checked by an expert but there was no packets loss on microwave link, no errors observed
If i put a decoder at Site A for Vlan 112, yes i see same artifacts!
Mar 22, 2026Guru - Experienced User
CHO29 wrote:If i put a decoder at Site A for Vlan 112, yes i see same artifacts!
Ok, I think that rules out the microwave link.
If you switch the two sources, does the problem move with the source, or does it stay with the VLAN?
