CHO29
Mar 21, 2026Tutor
Mosaic on decoded IP Stream
Hello guys, I have a network remote comprising of switch netgear gs724T. On One site two different stream are present on the switch with different Vlan and Multicast address Site A 1. Vl...
BrettD
Mar 24, 2026NETGEAR Employee
Have you set Jumbo frames (MTU) on all ports, including the microwave link? Try first on one switch in Site A with an encoder and decoder as StephenB suggested previously but with the MTU changes. Make sure you follow the network set up guide for your video equipment to make sure no additional changes are made but generally video over ip needs multicast and MTU set correctly.
Mar 25, 2026Guru - Experienced User
BrettD wrote:Have you set Jumbo frames (MTU) on all ports, including the microwave link?
CHO29: If the traffic on the microwave link is tagged, then setting the MTU to the usual 1500 could result in some packet fragmentation, particularly on the i-frames in the video stream. You'd want at least 1522.
Obviously check the microwave link manual to find out the max MTU it can handle. Or use ping to figure out the ceiling.
The encoder might also have a setting to limit max packet size.
