CHO29
Mar 21, 2026Tutor
Mosaic on decoded IP Stream
Hello guys, I have a network remote comprising of switch netgear gs724T. On One site two different stream are present on the switch with different Vlan and Multicast address Site A 1. Vl...
CHO29
Mar 25, 2026Tutor
Today i have perform a test for the vlan 112 on site where i decoded it on another port configure with vlan 112 and there is no artifacts confirm
Mar 25, 2026Guru - Experienced User
CHO29 wrote:Today i have perform a test for the vlan 112 on site where i decoded it on another port configure with vlan 112 and there is no artifacts confirm
Did you check the MTU settings as BrettD suggested?
Check this in the encoder and decoder, as well as the switch and microwave link.
