endian
Jan 15, 2026Aspirant
MS108EUP not supporting LLDP in a good way?
Hi, I am working quite a bit with hardware and software POE negotiation, and my view of the 802.3 standard is that the switch should announce it's LLDP capabilities and settings (including Power-...
endian
Jan 16, 2026Aspirant
There is a more competent switch called MS108TUP. Might these measurement be supported there?
- schumakuJan 16, 2026Guru - Experienced User
The MS108TUP does - different from the MS108EUP - support LLDP and it's configurations. So please give it a try, and let the community know.
