tigo13
Apr 17, 2024Star
MS510TXM, firmware V1.0.5.21
Updated a couple of switches to this new firmware V1.0.5.21 from 1.0.5.17, and within 72 hours, each switch suddenly failed. Am running multiple VLANs, and all of a sudden the VLANs would stop workin...
- May 29, 2024
Version1.0.5.23 seems to be stable - . Just completed 7 days without any issues. Will close the topic on the 10th-day.
All's good.
NAhDA
Apr 24, 2024Tutor
I’m seeing the exact same symptoms here. First locked up on Sunday 4/21, 2nd occurrence today 4/24. I have now rolled back to the previous firmware (V1.0.5.17) which I too found to be very stable..
schumaku
Apr 24, 2024Guru - Experienced User
Have to join this club, too. Switch remained operational basically, but loosing the admin Web UI. Re-activated v1.0.5.17 from the dual flash. Nothing in the syslog data collection, except of the traces from the subsequent reboots.
- Re7r0sApr 25, 2024Initiate
Exactly this.
Lost GUI/management functionality.
Reboot fixes it for 2-3days and then breaks again.
Rolled back to .17
- RennaDApr 26, 2024NETGEAR Moderator
Hi,
Thank you for reporting this. We will check this internally and keep you updated on any developments.
Have a lovely day,
RennaD
NETGEAR Team
