philippemaurice
Jun 29, 2023Aspirant
MS510txm slow down - bringing the whole network down
I purchased aMS510TXM switch to connect my Synology NAS1821+ to it's 10G connection as well as my Mac studio for video editing purposes, a few times the switch would slow down the network ( file tran...
tigo13
Jul 04, 2023Star
Have you tried disabling the Mac Studio - Ethernet port and re-enabling it?
I have a similar setup plus a Wifi AP connected to the switch, and I find that the Mac Studio ethernet is unreliable. When transferring files, - I find the computer using the Wifi 80% of the time vs the ethernet. As the AP is connected to the same switch - without any issues - I simply suspect the ethernet port is the issue. I'm yet to be bothered enough to try dock ethernet instead.
