--shaun--
May 12, 2022Aspirant
MS510TXPP logout issue
 I'm seeing an issue with an automated solution controlling a MS510TXPP.     I have the following workflow:   login  navigate to port details page  get port status and speed  logout   this is repeated...
JohnC_V
May 20, 2022NETGEAR Employee Retired
Hi --shaun--,
Welcome to our community! 🙂
It seems that you are having issues with your switch. I suggest upgrading the firmware of the switch first to the latest version and then resetting it to factory default. Let's see if the issue goes away after the firmware update.
John
NETGEAR Community Team
- --shaun--May 20, 2022Aspirant
Hi John,
we also have another switch that has the later version of firmware install and it also has the same issue with out the 10 second sleep in the logout code.
thou we do have another netgear switch which using the same method of controlling does not need the 10 second sleep
Thanks
Shaun
