Taker86's avatar
Taker86
Follower
Sep 20, 2024
MS510TXUP, firmware V1.1.0.7: Port speed issue
Hi all,
it's my first post here.
I've two MS510TXUP and after the latest update (V.1.1.0.7) I think something changed on port speed autosensing. One port for each switch now negotiates at lower speed than before:
- On switch 1, a port used for a Netgear WAX630 before was negotiating a 2.5Gbit (20m CAT6 cable), now is working at 100mbit. Using a 1m cable the access point negotiates at full 2.5Gbit speed. Trying to force 2.5Gbit with the 20m cable breaks the connection.
- On switch 2, a port used for a Macbook with USB-C ethernet adapter, now negotiates 1Gb but before was working a 2.5Gbit. At 1Gbit I have issues, if I force 100mb works well. Trying to change cables with 0,5m-1m-2m doesn't change nothing. It's stable only at 100mb. The same Macbook with the same ethernet adapter align at 2.5Gbit on switch 1.
I also tried resetting a switch and configuring as new without restoring a backup. Changing ports is useless. No way to fix.
It's a strange issue for me. Any advice?
No RepliesBe the first to reply
ProSupport for Business
