TenacIT_Support's avatar
Apr 29, 2019
MTU Issues over LACP trunk link
Hi, We have two XS716T ProSafe switches and a 2 port LAG group is used as a Trunk link between them. All our interfaces are set to 9000 MTU, but we only get 1500 over the LAG link. Has anyone seen...
  • schumaku's avatar
    Apr 29, 2019
    Port Configuration ... use All or LAG ... there I would expect the controls to set the LAG Frame Size.
ProSupport for Business
