fritsn's avatar
fritsn
MTU on port with tagged VLAN
The default for the MTU configuration on all ports is 1518, while a VLAN tagged ethernet frame can be as large as 1522 with a L3 payload MTU of 1500. Should I change all MTU values to 1522 for ports ...
  • Carl_z's avatar
    Carl_z
    Jan 03, 2017
    Hi firstsn,
    Yes, all right.
    In the 'Monitoring / Port Detailed Statistics' menu,  'Packets Transmitted > 1518 Octets  it include 4 bytes VLAN-tag.
    Regards
    Carl
ProSupport for Business
