vlan
14 TopicsThree GS308E, PFSense, cannot get VLAN working on third switch
I'm working on getting VLAN setup in my home network. All of the switches are GS308E and have the VLAN turned on for the type "Advanced 802.1Q VLAN". The "LAN" coming into Port 1 of Switch 1 is coming from the TPLink Switch that is connected to the PFSense box. Switch 1 with Port 2 connects to Switch 2 with Port 1. The same for Switch 2 Port 2 connects to Switch 3 with Port 1. Eventually Switch 3 with Port 2 will connect to a ReoLink PoE for my Cameras/Frigate setup. On Switch 1: Ports 6, 7, and 8 setup for VLAN 400. Ports 3 setup for VLAN 300. Ports 2 setup to go to Port 1 of Switch 2 Ports 1 setup to connect to the LAN On Switch 2: Port 1 is connected to Switch 1 Port 2 Port 2 is connected to Switch 3 Port 1 No VLAN has been setup at this point on this Switch On Switch 3: Port 1 is connected to Switch 2 Port 2 Port 8 is setup for VLAN 602 For all the Switches I have the VLAN 1 which is the default VLAN. For Switch 1, I'm able to connect my laptop with Ubuntu 24.04 and a Raspberry Pi 5 with Ubuntu 24.04 just fine to Port 6-8. I've tried to connect another computer (Ubuntu 24.04) to Switch 3 Port 8, but it fails to connect. I've taken my laptop and tried, but it also doesn't connect. Now when I connect to like Switch 3 port 6, it connects just fine. I started this post last night, but just finishing it up this morning. I'll dig back into the setup of things and see if I have done something incorrectly. Below is the setup of PFSense and an outline of how I have configured the Switches. If there is something else that I'm not included, please ask for it and I'll see if I can capture it, as I'll be messing around trying to get this to work. I've put in screen shots of the PFSense setup - put in bold of my comments so they stand out... PICS will be done during edits of this post - won't post to start... In Pfsense I can see my three switches (which have not been assigned a static IP at this point) In Pfsense, these are the VLAN setup. These are the Interface Assignments: Here is the Configuration of the SecurityCams2 (VLAN 602) The configuration of the DHCP Servier for VLAN 602 The last part, the Rules for the new VLAN. Switch Configurations =================== Ports-Connections and VLAN assignment ====== Switch 1 Port 1 - Connects to the LAN of the PFSense Box Port 2 - Connects to the Port 1 of Switch TWO Port 6 - VLAN 400 Port 7 - VLAN 400 Port 8 - VLAN 400 Switch 2 Port 1- Connects to LAN of the PFSense box going to Switch 1 port TWO Port 2- Connects to the Port 1 of Switch THREE Switch 3 Port 1 - Connects to LAN of the PFSense box going to Switch 2 port TWO Port 2 - Will connect to another switch, but have not connected at this point. Port8 - VLAN 602 VLANs Definition in Switch 1 --------------------------- VLAN=1 (Default) Port 1 - U Port 2 -U Port 3 - E Port 4- U Port 5- U Port 6- E Port 7- E Port 8- E VLAN=300 Port 1 - T Port 2 -T Port 3 - U Port 4- E Port 5- E Port 6- E Port 7- E Port 8- E VLAN=400 Port 1 - T Port 2 -T Port 3 - E Port 4- E Port 5- E Port 6- U Port 7- U Port 8- U VLANs Definition in Switch 2 --------------------------- VLAN=1 (Default) Port 1 - U Port 2 -U Port 3 - U Port 4- U Port 5- U Port 6- U Port 7- U Port 8- U VLANs Definition in Switch 3 --------------------------- VLAN=1 (Default) Port 1 - U Port 2 -U Port 3 - U Port 4- U Port 5- U Port 6- U Port 7- U Port 8- E VLAN=602 Port 1 - T Port 2 -E Port 3 - E Port 4- E Port 5- E Port 6- E Port 7- E Port 8- U PVID table ========= Switch 1 Port 1 - 1*, 300, 400 Port 2- 1*, 300, 400 Port 3- 300* Port 4- 1* Port 5- 1* Port 6- 400* Port 7 - 400* Port 8 - 400* Switch 2 -------- Port 1 - 1*, 602 Port 2- 1* Port 3- 1* Port 4- 1* Port 5- 1* Port 6- 1* Port 7 - 1* Port 8 - 602* Switch 3 Port 1 - 1*, 602 Port 2- 1* Port 3- 1* Port 4- 1* Port 5- 1* Port 6- 1* Port 7 - 1* Port 8 - 602*GS308Ev4, GS305E - Help with uplinks/downlinks
Could I please have some help or confirmation that I have these setup correctly? I'm weary that they are because I sometimes have trouble connecting to the admin interfaces on these switches. I've already locked myself out of about 5 of these (they become unreachable) and had to do factory resets and start over. Other times, I login and the admin pages don't fully load. Or sometimes they load with weird names and labels. Sometimes I logout and chrome says "no data from site". I'm concerned I'm losing some packets somewhere. But generally speaking, everything is working and the untagged (U) vlan access ports are divvying out the correct ip addresses and devices are communicating within themselves ok. I don't think I'm understanding how the uplinks/downlinks need to be tagged, or untagged. Here's the big picture. Looking at it on paper makes me feel like I'm way out of league. There's a lot of empty ports, I'm just starting. Here's the 4 port setup on the router Let me just start down the port 1 trunk (stuff on left of picture). Here's the setup of GS308Ev4-1 for VLAN1 Same router VLAN31 Same router pvid And then both GS305E-1 and -2 are setup the same which is: How am I doing?812Views0likes18CommentsVLAN
Hi an alle, ich habe einen GS752TXPv3 Switch und würde gerne ein VLAN 50 untagged erstellen 192.168.50.0/255.255.255.0 im VLAN1 - 192.168.1.0/255.255.255.0 läuft ein DHCP Server für VLAN1 u. VLAN50 Wie muss ich das VLAN50 am Switch konfigurieren das der DHCP relay zu diesem DHCP funktioniert ? Wie bekomme ich ein Routing von VLAN50 zu VLAN1 konfiguriert ?Howto change management vlanid on gs724T
Hi Everyone, I have a Prosafe XS716T here where I need to change management VLAN to 12 instead of 1. I've read that changing is possible and has solved some cases of networking but I haven't really found the option in my web interface. Maybe you can point in the right direction for that? Thanks a lot, I appreciate all the help I can get.SolvedHow to display VLAN settings using. Web Management
How can we display the VLAN settings using the Web Management ? Going I the VLAN setting tab and enabling will destroy the current settings,, as stated in the user guide : […], select the Enable radio button and continue with Step 8. Otherwise, see Step 9. A pop-up window opens, informing you that the current VLAN settings will be lost.Solved1.1KViews0likes1CommentModel nunmber= GS748TPS and Serial Number = 23R725xxxxxxx
I have an issue to make a trunk with this model of switch since there is no VLAN port membership in the GUI interface available to make trunk ports or even assign tagged ports. Tought it was a problem in the firmware but the firmware is updated to the latest version, the other version of GS752TPS doesn't have this issue and work well. Hardware version = 01.00.00 firmare version =5.2.0.11 I need to find a solution to this problem. Thank you in advance.SolvedS3300 inter-VLAN Routing Issue
I have just purchase an S3300-28X and S3300-52X and am getting to grips with all the features. Most features seem pretty straight forward so far, but I'm having real issues setting up inter-VLAN routing. I've been unsuccessfully banging my head against the wall for a few days now, so hopefully someone here will be able to shine some light on where I'm going wrong. I've factory-reset the S3300-28X and setup a simple configuration for testing: VLAN10 Interface IP: 10.0.10.1 Subnet Mask: 255.255.255.0 VLAN20 Interface IP: 10.0.20.1 Subnet Mask: 255.255.255.0 Port 1/g14 PVID: 10 VLAN Member: 10 VLAN Tag: None Port 1/g16 PVID: 20 VLAN Member: 20 VLAN Tag: None I initially setup the VLANs with the routing wizard, selecting the appropriate tags as untagged. After checking the PVID configuration I connected a workstation to each port with the following manual IP settings: Workstation (1/g14) IP Address: 10.0.10.123 Subnet Mask: 255.255.255.0 Default Gateway: 10.0.10.1 Workstation (1/g16) IP Address: 10.0.20.123 Subnet Mask: 255.255.255.0 Default Gateway: 10.0.20.1 Each workstation can ping default gateways on either VLAN, but the workstations cannot ping one-another. I feel like I've tried every possible setting in the PVID Configuration sections but nothing seems to work. So, could someone please suggest where I've gone wrong or what I should try next? Thanks!Solved5.2KViews0likes3CommentsSame VLAN on two switches (S3300's) will not communicate
Hi, probably its just a stupidity issue on my side but I can't get this to work. I am trying to get two boxes to communicate over two switches using a particular vlan. This is actually the simplified solution attempt for a more complex issue but can't even get this to work:( I've been following https://kb.netgear.com/11673/How-do-I-setup-a-VLAN-trunk-link-between-two-NETGEAR-switches this guide. Test Setup : 2x S3300 (one on 6.6.14, one one .17) connected via Trunk 1x ESX box with a vSwitch with multiple vmknics, one of these on the relvant vlan (6) 1x Windows Box (no VLAN setup on nic) Switch A (stacked with another S3300) Interface PVID VLAN Member VLAN Tag Acceptable Frame Untagged VLANs Tagged VLANs Comment 2/g14 6 6 None Admit All 6 None TestPort Local Switch 2/xg25 1 1,6 6 Admit All 1 6 Trunk Link 2/xg28 1 1,5-9,18,19 5-9,18,19 Admit All 1 5-9,18,19 ESX Box ESX box with a vmknic on VLAN 6 on Switch A, Trunk configured on 25 according to KB. 14 is a testport - if I connect the Windows box to this port the connection works (- - > Intra Switch VLAN is fine) Switch B Interface PVID VLAN Member VLAN Tag Acceptable Frame Untagged VLANs Tagged VLANs Comment 1/g22 6 6 None Admit All 6 None Windows Box 1/g23 1 1,6 6 Admit All 1 6 Trunk Link If the Windows Box is connected to B/22 I can't communicate with it and I can't see why not I have tried a lot of things already, setting up VLAN IPs for example on both switches to check whether its a port issue or not. But its always the same pattern - everything local is working fine but as soon as the traffic has to flow to the other switch its not. Everything on VLAN 1 is working fine o/c, just not on another VLAN. Looking for any kind of clue, totally lost :( Thanks for reading.Solved8.4KViews0likes9CommentsCan't change untagged VLAN on GS752TP with 6.0.1.18 Firmware
I have 2 GS752TP Switches in the office, switch #1 is running 6.0.1.18 switch #2 is running 6.0.1.16. I have the 3 default VLANs on each switch, and then 8 additional VLANs that I'd added. With the exception of the VLANs, the password, and setting up Network time, these switches are basically at factory default. After adding the new VLANs I go into Switching->VLAN->Advanced->VLAN Membership On Switch #1: For my setup I need to set several of the ports to Untagged for VLANs other than VLAN 1. To start I'll go to say Port 1, and change it from U -> T. When I attempt to apply this change I get an error that "VLAN 1: VLAN was not created by the user". I get this same error when I try to make any change to VLAN 1, which means that I can set any VLAN other than VLAN 1 as the Untagged VLAN for the port. On Switch #2: I follow the same steps as above, and I'm allowed to save the changes for Port 1 VLAN 1. I can then go to VLAN 10 (one of the new ones I've created) and change Port 1 from ' ' -> U and then apply that change. Setting changes between Switch #1 and #2 are the same as near as I can tell (both switches have been factory reset, then stepped through the configuration changes on each one, the only difference would be any difference between factor defaults on 6.0.1.18 and 6.0.1.16, I haven't seen any as I've gone through and looked). I did read something that made me think I might need to disable Routing Mode with the latest firmware to make the changes to the VLAN I'm trying, so I tried that but still get the same error. It doesn't appear that the switch can be downgraded to 6.0.1.16 because of the firmware updates for POE that came along with 6.0.1.18. Any ideas why I can't change the Untagged VLAN for a port? Thanks.SolvedSimple VLAN without VLAN-aware router and DHCP aka Port-based VLAN
I did manage to get the tagged VLANs (802.1Q) working with DHCP, mutiple switches AND VLAN-aware router - the whole shebang. However, I tried to poke around with the simple setup with not vlan-aware router and no tagging and....it just didn't work :O My setup is following: router<--port1-->switch<---port4-->PC vlan1 contains all 8 ports untagged vlan 10 contains port 1+4 untagged port 4 PVID = vlan10 All the devices are on the same subnet. Switch is a Netgear108Tv2 with the latest firmware (5.4.2.27) 1. DHCP isn't leasing me any IPs - I get APIPA 2. Even with static IP (incl. router as gateway), I cannot ping either the router itself or anything else.... What am I doing wrong here ? I've read on various forums, that GS108Tv1 had port-based VLAN option which easily managed a setup like this, V2 is apparently only supporting 802.1Q-VLAN, which still should support untagged VLANs and a vlan-not-aware router, isn't it ? I also found this post, where one of the users "somehow" as he puts it, managed to make it work: https://community.netgear.com/t5/Wired-Network-Adapters/Is-port-based-VLANs-using-GS108Tv2-still-possible/td-p/473280Solved
