Mohamed_Farid's avatar
Aug 14, 2017
Model nunmber= GS748TPS and Serial Number = 23R725xxxxxxx
I have an issue to make a trunk with this model of switch since there is no VLAN port membership in the GUI interface available to make trunk ports or even assign tagged ports.
Tought it was a problem in the firmware but the firmware is updated to the latest version, the other version of GS752TPS  doesn't have this issue and work well.
Hardware version = 01.00.00
firmare version =5.2.0.11
I need to find a solution to this problem.
Thank you in advance.
  • Mohamed_Farid,
    Thanks for the update.  I'm glad to know that the problem has been resolved. :)
    Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    Cheers,
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi Mohamed_Farid,
    Welcome to the community! Smiley Happy
    What browser are you using to access the web-GUI of the GS748TPS?  Have you tried using other browsers like Firefox or Chrome then try to set up VLAN membership and set port tagging?
    Kindly post a screenshot of the error you have encountered wherein there is no VLAN membership on the web-GUI of the GS748TPS.
    Kindly read pages 4-18 to 4-20 of the GS748TPS user manual here on how to set up VLAN membership and set the port(s) as tagged or untagged.
    DaneA
  • DaneA's avatar
    DaneA
    Mohamed_Farid,
    I just want to follow-up on this.  We’d greatly appreciate your feedback.
    DaneA
    • Mohamed_Farid's avatar
      Mohamed_Farid
      Hello all ;
      I used both the google chrome and firefox browsers with no succes to access the VLAN tags for ports.
      I will send to you later a picture of the issue  once the access is obtained to the old netgear swith but FYI the config page shows empty page when trying to assign tagged ports to a VLAN.
      At the end i have a question regarding the netgear swithces in general, how to assign multiple VLAN membership to a single ports.
  • DaneA's avatar
    DaneA
    Mohamed_Farid,
    Cheers,
    DaneA
ProSupport for Business
