Mohamed_Farid
Aug 14, 2017Aspirant
Model nunmber= GS748TPS and Serial Number = 23R725xxxxxxx
I have an issue to make a trunk with this model of switch since there is no VLAN port membership in the GUI interface available to make trunk ports or even assign tagged ports.
Tought it was a ...
- Sep 26, 2017
Thanks for the update. I'm glad to know that the problem has been resolved. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
DaneA
Aug 21, 2017NETGEAR Employee Retired
Hi Mohamed_Farid,
Welcome to the community!
What browser are you using to access the web-GUI of the GS748TPS? Have you tried using other browsers like Firefox or Chrome then try to set up VLAN membership and set port tagging?
Kindly post a screenshot of the error you have encountered wherein there is no VLAN membership on the web-GUI of the GS748TPS.
Kindly read pages 4-18 to 4-20 of the GS748TPS user manual here on how to set up VLAN membership and set the port(s) as tagged or untagged.
DaneA
