Mohamed_Farid
Aug 14, 2017Aspirant
Model nunmber= GS748TPS and Serial Number = 23R725xxxxxxx
I have an issue to make a trunk with this model of switch since there is no VLAN port membership in the GUI interface available to make trunk ports or even assign tagged ports.
Tought it was a ...
- Sep 26, 2017
Thanks for the update. I'm glad to know that the problem has been resolved. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
monthippy
Oct 09, 2017Aspirant
the serial no. on my NTV300/Neo tv 2 player has been covered up. that way when I got it.Need number to do anything. [email protected] Howard
DaneA
Oct 10, 2017NETGEAR Employee Retired
Hi monthippy,
Welcome to the community! :)
It would be best if you post your concern and create a new discussion to the correct board below:
https://community.netgear.com/t5/Streaming-Video/bd-p/home-steaming-players
DaneA
