Mohamed_Farid's avatar
Aug 14, 2017
Model nunmber= GS748TPS and Serial Number = 23R725xxxxxxx
I have an issue to make a trunk with this model of switch since there is no VLAN port membership in the GUI interface available to make trunk ports or even assign tagged ports.   Tought it was a ...
  • DaneA's avatar
    Sep 26, 2017
    Mohamed_Farid,
    Thanks for the update.  I'm glad to know that the problem has been resolved. :)
    Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    Cheers,
    DaneA
    NETGEAR Community Team
ProSupport for Business
