Mohamed_Farid
Aug 14, 2017Aspirant
Model nunmber= GS748TPS and Serial Number = 23R725xxxxxxx
I have an issue to make a trunk with this model of switch since there is no VLAN port membership in the GUI interface available to make trunk ports or even assign tagged ports.
Tought it was a ...
- Sep 26, 2017
Thanks for the update. I'm glad to know that the problem has been resolved. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
Mohamed_Farid
Aug 28, 2017Aspirant
Hello all ;
I used both the google chrome and firefox browsers with no succes to access the VLAN tags for ports.
I will send to you later a picture of the issue once the access is obtained to the old netgear swith but FYI the config page shows empty page when trying to assign tagged ports to a VLAN.
At the end i have a question regarding the netgear swithces in general, how to assign multiple VLAN membership to a single ports.
Thank you in advance.
DaneA
Aug 31, 2017NETGEAR Employee Retired
Thanks for the feedback. Since you mentioned that the config page shows an empty page, I suggest you to factory reset the GS748TPS then reconfigure it from scratch.
Kindly access the articles below and use it as your guide in setting up VLANs and appropriate tagging on the ports:
How to create Layer 2 VLANs on NETGEAR ProSAFE Switches
How do I setup a VLAN trunk link between two NETGEAR switches?
DaneA
NETGEAR Communtiy Team
- DaneASep 04, 2017NETGEAR Employee Retired
Just following up again. Were you able to factory reset your GS748TPS then reconfigure it from scratch and check if the config page shows an empty page? Also, were you able to access the articles I've shared and used it as your guide?
We’d greatly appreciate your feedback.
DaneA
NETGEAR Communtiy Team - Mohamed_FaridSep 04, 2017Aspirant
Hello ;
I have reset the configurations of the netgear switch but the problem still exits, I have read this configurations before in the article links you mentioned but still don't see how to assign multiple VLAN IDs to a port in a Port-Vlan ID's configurations in the switch.
I have attached to you below a picture of the empty units that are found for tagged or untagged ports...this prevents me from assigning VLANs to the switch ports.
Thanks for the feedback. The image you have provided is not the page where to assign a port(s) to VLAN ID. Just want to verify, were you able to set the ports as untagged (U) or tagged (T) to the corresponding VLANs?
Kindly refer to the image below and follow the steps. Read the notes indicated as well.
As reference above, kindly read pages 4-18 to 4-20 of the GS748TPS user manual here on how to set up VLAN membership and set the port(s) as tagged or untagged.
Also, if ever the configuration screen does not display correctly, try to update the version of the browser you are using.
DaneA
NETGEAR Community Team- Mohamed_FaridSep 04, 2017Aspirant
Hello,
The image that you displayed is the same as mine but when i click on tagged or untagged ports button it doesn't show anything .... I will try to update my firefox/google browsers.
Thank you for your reply.
