Mohamed_Farid
Aug 14, 2017Aspirant
Model nunmber= GS748TPS and Serial Number = 23R725xxxxxxx
I have an issue to make a trunk with this model of switch since there is no VLAN port membership in the GUI interface available to make trunk ports or even assign tagged ports.
Tought it was a ...
- Sep 26, 2017
Thanks for the update. I'm glad to know that the problem has been resolved. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
DaneA
Aug 24, 2017NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback.
DaneA
- Mohamed_FaridAug 28, 2017Aspirant
Hello all ;
I used both the google chrome and firefox browsers with no succes to access the VLAN tags for ports.
I will send to you later a picture of the issue once the access is obtained to the old netgear swith but FYI the config page shows empty page when trying to assign tagged ports to a VLAN.
At the end i have a question regarding the netgear swithces in general, how to assign multiple VLAN membership to a single ports.
Thank you in advance.
- DaneAAug 31, 2017NETGEAR Employee Retired
Thanks for the feedback. Since you mentioned that the config page shows an empty page, I suggest you to factory reset the GS748TPS then reconfigure it from scratch.
Kindly access the articles below and use it as your guide in setting up VLANs and appropriate tagging on the ports:
How to create Layer 2 VLANs on NETGEAR ProSAFE Switches
How do I setup a VLAN trunk link between two NETGEAR switches?
DaneA
NETGEAR Communtiy Team- DaneASep 04, 2017NETGEAR Employee Retired
Just following up again. Were you able to factory reset your GS748TPS then reconfigure it from scratch and check if the config page shows an empty page? Also, were you able to access the articles I've shared and used it as your guide?
DaneA
