fritsn
Dec 23, 2016Aspirant
MTU on port with tagged VLAN
The default for the MTU configuration on all ports is 1518, while a VLAN tagged ethernet frame can be as large as 1522 with a L3 payload MTU of 1500. Should I change all MTU values to 1522 for ports ...
- Jan 03, 2017
Hi firstsn,
Yes, all right.
In the 'Monitoring / Port Detailed Statistics' menu, 'Packets Transmitted > 1518 Octets it include 4 bytes VLAN-tag.
Regards
Carl
fritsn
Jan 03, 2017Aspirant
Hi Carl,
When I said MTU earlier, I really meant the 'Maximum Frame Size' configuration in the 'Switching / Ports' menu.
So you say this:
The VLAN tag is not counted against the Maximum Frame Size, so there is no need to put the number to 1522 for VLAN tagged ports if a normal MTU of 1500 is used for the payload.
True?
In the 'Monitoring / Port Detailed Statistics' menu, I see for a VLAN tagged port: 'Packets Transmitted > 1518 Octets'.
Does the packet size in this menu include the 4 bytes VLAN-tag?
Frits
Carl_z
Jan 03, 2017NETGEAR Expert
Hi firstsn,
Yes, all right.
Regards
Carl
