TommySRK
Sep 18, 2021Follower
My GC510PP config missing "ip address dhcp" for "interface vlan 4089", how to add it?
Below, is some part of configuration of my GC510PP Insight Cloud Managed Switch. .....
interface vlan 1
routing
ip address dhcp
exit
interface vlan 2
routing
ip address dhcp
exit
interface vlan ...
schumaku
Sep 21, 2021Guru - Experienced User
The
ip address dhcp
is "just" to allow the routing adapter for that VLAN to run on a DHCP client so it does get it's config from the adjacent DHCP server. Coplete unrelated to the DHCP ability for that VLAN I'd say.
Is there a DHCP server atached to that VLAN 4089?
Any specific reason for (kind of abusing) this default VLAN 4089?
