cybr-g's avatar
cybr-g
What is the result of selecting "DHCP" mode for JGS524PE ?
Hi, the JGS524PE has a "DHCP" option that can be activated of disabled.
But the documentation does not explain much more on the result of this activation.
More precisely I would like to know when the "DHCP" option is activated, does it activate a DCHP server on the JGS524PE or on the contrary, it makes the JGS524PE ask its IP to the DHCP server of the network ?
I think the way the option is presented is very obscure for new customers like me.
I have put a screenshot of the config page illustrating the option menu
  • schumaku's avatar
    schumaku
    Quickly fly over the fine documentation Gigabit Ethernet Smart Managed Plus Switches User Manual valod for Models GS105Ev2 GS105PE GS108Ev3 GS108PEv3 GS116Ev2 GS305E GS308E JGS516PE JGS524Ev2 JGS524PE starting from p.15 - it's always about the IP config assigned to the switch by it's DHCP client, served from a DHCP server on the network.
    No Smart Managed Plus or Smart Managed Pro switch does contain a DHCP server for one or multiple VLANs.
    • cybr-g's avatar
      cybr-g
      Thank you for your answer.
      I was confused by the default 192.168.0.239 configuration IP.
      This IP changes accordingly after network DHCP configuration or user static IP configuration.
      • schumaku's avatar
        schumaku
        The default is DHCP, in case the DHCP request is not honoured, the switch does fall-back to the 192.168.0.239/24 address. This can be useful for an initial config of a switch purely standalone and connected to a computer.
ProSupport for Business
